550sx pole spring upgrade???
» Hydro-Turf
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jun 2007
    Berkeley Heights / Seaside Heights N.J.
    my 550sx needs a new handle pole spring. Is there a stronger "race" spring? or is there any other spring i can get that is an improvement over stock?
    Anyone with experience on this topic?
    thanks!
    -Mike
    05' Superjet
    91' 650sx
    89' 650sx
    91' 550sx
    93' Seadoo SPX
    I dream skis gemiller's Avatar
    Jun 2007
    Pine Grove, PA
    Re: 550sx pole spring upgrade???
    just use two, thats what a lot of em do.
    1994 750SX: MSD Ign. Enhancer, Trigger throttle, Quick steer plate w/ 7 degree bars, JD ride plate & intake grate, Skat Trak impeller, Handle pole spring, Reeds, 44mm Keihin taper bored carburetor, Factory Pipe, Milled Head, Hydro Turf pad, Primer Kit
    1989 650SX: Trigger throttle, After market ride plate & intake grate, Handle pole spring with bigger handle pole bushings, Reeds, West Coast pipe, 44 Mikuni BN, Primer Kit
    1999 Kawasaki Ultra 150, 2006 Sea Doo GTX
    PWCToday.com Is My Home Away From Home Fox's Avatar
    Mar 2007
    Orlando, Flaw
    or do some curls.
    Fox the Pirate. UWP IJSBA Flagman & Course Marshall
    Sailing :
    1988 sj550
    Warning:
    The above post contains pessimism and player hating to the highest degree.
    Sep 2005
    AZ
    There never was a stock pole spring for any 440/550's...all aftermarket. You can use 2 springs, there are 2 different styles. I did this to one ski and the pole stays up about a foot and a half above the hood all on its own. Gordy30 on ebay sells a westcoast spring with 2 coils on the otside edges and then the "regular" style spring with one large coil in the center will fit in between the westcoast coils all on the same pivot bolt. Hard to explain...I have a picture at home.
    1992 Laser Jet F14 - Raced in 1992 World Finals.
    1992 550 SX - PJS Secret Weapon Big Bore, Kind of fast, LOL.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust. 45 MPH, yee ha!
    1976 JS 400 - Pretty much just a shell. Sure want to restore this some day!
    Jun 2007
    I actually have a west coast spring which i havent put on yet, but if you dont mind. i would really like to see what yours looks like with the other spring in the middle.
    05' Superjet
    91' 650sx
    89' 650sx
    91' 550sx
    93' Seadoo SPX
    PWCToday.com Is My Home Away From Home Laserman's Avatar
    Apr 2006
    Orlando, FL 32817
    Both springs is the way to go.
    1985 JS 550/750 Stand-up: http://www.pwctoday.com/f72/smileys-...50-114680.html
    1984 JS550 TYPHOON 750 conversion: http://www.pwctoday.com/f72/laserman...ct-186297.html
    1992 Sport Cruiser "Sportscar" Conversion: http://www.pwctoday.com/f72/laserman...-a-173049.html
    Here's a helpfull thread on 550\650 conversions: http://www.pwctoday.com/f72/just-ano...on-133898.html
    Frequent Poster rab2009's Avatar
    Sep 2006
    brighton, michigan
    i read a old thread on the x that said a 750 spring will fit
    1989 550 small mods
    89 550 (650 project ski on hold)
    87 550 stock (new cheaper project ski)
    Jun 2007
    It seems like most springs will universally fit.
    The one thats on there now is one of those double sided springs, which is broken on one side, I have a replacement westcoast double sided spring I have yet to put on it, I was just wondering what everybody else does to beef up their bars.
    Im definately interested in the idea of the "double spring" with a "single spring" in the center
    05' Superjet
    91' 650sx
    89' 650sx
    91' 550sx
    93' Seadoo SPX
    Sep 2005
    AZ
    Here it is with duals! I'd definitely recommend the metal sub plate as well since there is a lot of spring force with 2...just on the fiberglass it will probably break.
    Jun 2007
    very nice ski!
    I like that spring setup, Im going to look into getting a second spring + rub plate. Not easy to find good stuff though, I just have to keep watching ebay
    05' Superjet
    91' 650sx
    89' 650sx
    91' 550sx
    93' Seadoo SPX
