Results 1 to 10 of 15
    Sep 2007
    Loveland, CO
    1997 Yamaha WaveRunner 760 - burning oil?
    Well, I've owned our Yamaha WaveVenture/WaveRunner 760 and Kawasaki ZXI 750 for about a month now (bought after the motor in our Sea-Doo blew up).
    Anyway, Labor Day weekend was a big day on the lake. One of my friends had a ton of her friends over, and she, my friend, my other friend, and me were all responsible for taking them out and having fun. Anyway, I ran a tank through the Yamaha both Saturday and Sunday, a total of about 7 hours and 25 gallons of gas.
    I had filled the oil tank to the top Friday night, before putting it in the water Saturday morning (I'm gussing the oil tank is about 1 gal?). Anyway, I checked the oil level after pulling it out Monday evening (didn't ride at all monday), and there was only about a tank left.
    My question is, is this thing burning oil, or do these Yamahas just have a pretty rich oil/fuel mixture?
    Sorry for the rambling, I tend to get carried away sometimes.
    Thanks, tweak.
    Re: 1997 Yamaha WaveRunner 760 - burning oil?
    its a 2 stroke... sometimes they smoke a bit to show their power... But yeah it might be running a little rich on the oil side...
    I think you should take the motor out and give it to me... Well at least the cylinders...
    Oct 2003
    Wait, what did you expect regarding the oil in the oil tank?
    Water:'03Octane,'94B1,'95B1,Land:'06 Busa,'99GSXR750,'91Vmax,'91 5.0 GT, '86 SVO. Yes, I know..... I have a problem.
    Top Dog TOR*P*DO's Avatar
    in the garage doing mods
    so, 25 gallons gas, 3/4 gallon of oil makes 33 to 1
    kinda rich, but not out of line
    and it sure beats going weak on oil and seizing!!!!
    if you misjudged and it is 25 gallons gas to 0.5 gallons oil, that is 50:1 which is perfect!
    Get off the couch and Ride!!!!
    Resident Guru PWCToday.com Is My Home Away From Home monoshock's Avatar
    Apr 2006
    Lake City TN. Is that banjos I hear ??
    Check for leaks on the oil lines.
    And then change it over to premix, where you know how much oil it's getting.
    Cialis, it does a body wood.
    Tim
    PWCToday.com Is My Home Away From Home yamanube's Avatar
    Mar 2006
    My superjet burns oil too, its normal for yamaha 2 strokes.
    Sep 2007
    Loveland, CO
    Well, from reading what you guys have said, it sounds like it's nothing to worry about.
    My dad suggested removing the injectors and using pre-mix, but I don't really want to risk running too lean and seizing the engine. But, if the injector completely fouls, I guess I could learn to live with it.
    Quote Originally Posted by tweak
    My dad suggested removing the injectors smart Dad and using pre-mix, but I don't really want to risk running too lean and seizing the engine you risk that with an oil injection system failing. As long as you remember the oil (duh) in the premix, it will be there!. But, if the injector completely fouls, I guess I could learn to live with it like a top end rebuild????.
    Go Premix!!!
    Sep 2007
    Loveland, CO
    Wow, you have some good points there... Maybe I should just pull the injectors this winter and start using premix.
    If I were to do that, what kind of oil:fuel ratio would I be looking at? 40:1? 50:1?
    It may be stupid, but ya' only live once!
    1996 Kawasaki ZXI 750
    1989 MasterCraft Tri-Star 190
    Rippin' it up on Horseshoe Lake, Loveland, Colorado
    PWCToday.com Is My Home Away From Home Motoman25's Avatar
    Mar 2007
    Seaford, Long Island
    hah if that injector fouls you are gonna have a lot more than living with it....your gonna blow your motor cause its gonna run lean...
    premix it before something catastrophic happens to your motor from running on straight gas and then you will always know you are putting in 50:1 or more oil if you want to run richer than that
