787 Piston Backwards - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
    Top Dog billman100's Avatar
    Jul 2007
    North Dakota
    Re: 787 Piston Backwards
    Wasn't plugged in wrong. I am charging the battery overnight and I will give it a go tomorrow with the test light. I also thought about switching the wiring from the back cylinder to the front to see if I can get it to run on the front and rule out faulty wiring.
    Gen2 BOB JW850BB
    Quote Originally Posted by billman100 View Post
    This is old, but I but I have the same motor. I put the pistons in backward, broke the rings, realized what I had done, bought new rings, installed the correct direction and now I only get the rear injector to work. I can switch the injectors and they both work, but from my reading only the front injector should work at idle. mine is reverse now. also can't get the front injector to fire at all. replaced the mpem, same result. can someone help before this gets parted out?
    Mpem actually has nothing to do with the fuel injection, there is a Bosch controller on the back side of the MPEM case. it could be faulty.
    Jul 2007
    North Dakota
    Is that a replace-able part?
    Gen2 BOB JW850BB
    Jul 2007
    North Dakota
    I have a good known Mpem with bosch ecu so ruling that out, I'll just have to go through each wire individually and see if i ind a dead one
    Gen2 BOB JW850BB
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    What does inj trigger off of? 2 sensors like a Polaris stupid stator?, is there a trigger wheel?
    One sensor on the top of the mag housing , yes the trigger wheel is made onto the flywheel.
    Jul 2007
    North Dakota
    The crank position sensor which ohms out correctly in my case.
    Gen2 BOB JW850BB
