787 Piston Backwards - Page 2
Results 11 to 20 of 27
    Top Dog billman100's Avatar
    Jul 2007
    North Dakota
    Re: 787 Piston Backwards
    rear cylinder will run up to about 4k rpm but the front doesnt get any fuel
    Gen2 BOB JW850BB
    99 RFI's idled on both cyls.
    Jul 2007
    North Dakota
    what would cause the front not to inject?
    Gen2 BOB JW850BB
    Not getting a signal from the MPEM or bad injector.
    Are you sure you have the right wire hooked up to injector ??? I dont have a RFI to look at but the rave solenoid has the same plug so its easy to get the 2 confused
    Jul 2007
    North Dakota
    Switched injectors and got the same thing, have a known good mpem and that didn't change anything. i'll check the solenoid plug
    Gen2 BOB JW850BB
    Sep 2017
    Newyork
    Ive got 99 GTX RFI parts for sale, let me know if you need anything. MPEM, Injectors, Wire harness ETC.
    Jul 2007
    North Dakota
    trying to fix what i have if i can't it'll be parted out
    injector and rave solenoid hook up correctly*
    Gen2 BOB JW850BB
    Here is what I would do......The inj has 2 wires going to it,IIRC the positive is constant & the other wire is pulsed by a negative signal.
    Take a test light & see what happens when you crank it over & then go to the other cyl (bad) & see if you are getting the same signals.
    You probably have a broken wire or bad connection at MPEM or in the harness itself.
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Bet it's plugged in wrong, has anyone ever seen one injector harness go bad? I guess there are no rez packs involved. If it is the mpem I bet it's just a fet
    Aug 2015
    Birmingham
    This is everything ever I think, and pwm boost solinoids, idle valves, those old school bleed back 'lambda' kjet valves, led dimmers....
