Race / Pump Gas??
    PWCToday Newbie stabaan's Avatar
    Jul 2007
    SA
    Race / Pump Gas??
    Gudday all....First post!!!
    http://www.pwctoday.com/images/smilies/joke.gif
    I just got a 2005 sxr with R&D cast head, Factory Dry Pipe etc..etc...I read somewhere that you must not use pump gas with an aftermarket head. This true? I'm only using it for rec riding....
    Thanks!
    PWCToday Guru Hilli's Avatar
    Jul 2007
    S.MI. / FL.
    Re: Race / Pump Gas??
    1st, Welcome, think you'll like it here, 2nd I would say a compression test would give you a better idea on which fuel to run, unless that info came w/ski, head(?), T.
    '90 Mod. 650SX
    '94 Mod. Hulled Lamey PV B1
    '90-'91 IJSBA Region 7 Novice Class Slalom Champ.
    '90-'91 IJSBA Region 7 Novice Closed Course 2nd Place.
    '90-'91 IJSBA Region 7 Novice Overall 2nd Place.
    Team Butch / Son Skis Racing.
    Jul 2007
    SA
    No info with the ski, no.
    How do I tell from the compression test?
    Ta
    Jul 2007
    S.MI. / FL.
    OK, the test will give you amount of compression in each cyl. in lbs., unless you know someone who has the same set-up as you(or you could do a search in this forum) an example would be: 170-180lbs. 93-100octane.
    '90 Mod. 650SX
    Jul 2007
    SA
    Thanks, I'll have a look.
