Results 1 to 6 of 6
    Aug 2005
    Alberta Canada
    Air / Fuel Separator
    Hello,
    I've been looking into getting a Group K Separator for a while for my 99 GP 1200. It will bog down on hard turns once gas gets below 1/2 tank. It is a fairly modified ski that is currently running Full Spectrum 48's. I've got a dual fuel setup using the reserve and an in line restrictor installed also, but it still bogs. I was wondering if it is possible to setup the Group K Separator with the 3 pumps currently on the carbs? I assume I would have to tap some more connections onto the separator, but my main concern was how to route the return line...
    Tech Guru Resident Guru
    Feb 2002
    Fort Mohave, AZ
    Re: Air / Fuel Separator
    Our current seperator chambers are made with two inputs, but creating a custom unit with 3 inputs is no problem ... $65 for the kit with no fuel pump(s).
    Respectfully, Harry Klemm
    Quote Originally Posted by rob.bain
    Hello,
    www.groupk.com
    Aug 2005
    Alberta Canada
    Would I set it up like this?
    Feb 2002
    Fort Mohave, AZ
    It looks fine.... except the 18gph remote fuel pump needs to be between the filters and the carb input.
    www.groupk.com
    Aug 2005
    Alberta Canada
    Hi Harry,
    I want to set it up without using the remote pump, and instead use the existing 3 pumps built into the carbs. Is that possible and would I route it just like the diagram above?
    Thank you,
    Rob
    Feb 2002
    Fort Mohave, AZ
    The seperator "cannot" function with the carb mounted pumps ... it "mandates" the use of a remote pump ..... sadly, that's just the way it is.
    Harry
    Hi Harry,
    Thank you,
    Rob
    www.groupk.com
