Flywheel removal, 650sx
Results 1 to 10 of 20
    Sep 2006
    How do you remove the flywheel froma '91 650sx? Is a special tool required? Thanks in advance!
    Dave
    PWCToday.com Is My Home Away From Home professor9's Avatar
    Nov 2005
    Cranberry Township, PA
    Re: Flywheel removal, 650sx
    Harmonic balancer puller. Oh, and a spanner wrench to get on the drive coupler.
    Prof
    I dream skis 650sxNoobie's Avatar
    Nov 2003
    Michigan
    do your self a favor and go to a local dealer and order the flywheel puller and the holder wrench....i speak from experience (i.e learn the hard way)
    04 SX-R Stock w/ 0 degree UMI bars/ODI grips JSU spring tensioner
    89 650SX...
    Group K F650 mods (porting, milled head, pistons etc)
    38mm Carb w primer
    Blue Tau-Ceti FA
    Solas prop
    WestCoast pipe
    Stator rebuilt by Jetski Solutions
    Hydro-Turf
    UMI 0 Degree bars
    ODI Grips
    UMI Finger Throttle
    Quick turn plate
    Pole Spring
    New battery cables
    Jetsport rideplate
    Rule Bilge
    R&D Grate
    New Paint
    Exotic Signs Graphics
    Sep 2006
    I went to the dealership and was told that all that I needed was to use an air rachet on the nut in the middle of the flywheel.
    What is a spanner wrench? I have a puller.
    Resident Guru ang4th's Avatar
    Aug 2003
    Hamilton,ontario
    just a cheap puller then a impact wrench and it would eaily pop off :0
    "It is better to keep your mouth shut and appear stupid than to open it and remove all doubt."
    Hamilton Ontario Canada . need old school Kawasaki 650 , 750 or some basic superjet parts and you are within Canada ? message me I may have parts available
    PWCToday Guru x2freestyle86's Avatar
    Connecticut
    no need to buy a puller.
    take a chunk of steel, cut three slots in it.
    Back out the bolt holding on the flywheel about 5 or six turns,thread the threee screws into the flywheel, tighten them evenly against the bolt in the crank, tap on the center with a hammer a few times, itll pop right off. ( it takes a little to make the tool, but once its done, its free an works very well,)
    www.myspace.com/74dart
    650 SX - 1988
    650 SX - 1991
    650 X2 - 1986-780 project
    670 x2 - 1986/91-^^
    650 SX - 1989- freestyle project
    650 SX - 1990
    Sep 2006
    I'm having trouble backing out the flywheel bolt.
    Resident Guru chrisdoc0608's Avatar
    Jul 2006
    nc
    dont make the tool. go to an auto store get a universal flywheel puller (10- 15 bucks) take a large rachet w/ breaker bar if needed if you dont have air tools. put a bungie cord in one of the spark plug holes and turn the crank till the piston squeases on the cord. once this is done take your wrench and break the bolt loose, do not remove it. take the puller and thread your three screws into the flywheel through the puller, make sure you dont thread them too far so you dont damage anything. take the center screw and tighten it up on the flywheel bolt, if tightening it doenst break the flywheel loose then give the center bolt a few hits with a hammer. worst case you will have to heat it up, but try the first steps before you do that.
    1992 701 custom RN arm jerker
    Sep 2006
    You're a genious. That trick with the bungee cord is what I was looking for. Thanks!
    Jul 2006
    nc
    no problem good luck!
