Turbo Aquatrax ECU alternative thread - Page 21
Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 201 to 210 of 213
  1. #201
    PWCToday Guru skidoc's Avatar
    May 2012
    tampa
    Re: Turbo Aquatrax ECU alternative thread
    No Repair or re-flash on stock Honda Aquatrax ECM
    Jet Skis International
    Brian Brocksmith
    813-413-7544
    http://jetskisint.com
    Free Aquatrax Tech support
    https://www.facebook.com/pages/Jet-S...91943504243227
  2. #202
    Jul 2016
    Australia
    Ok.
    So how will something like this: http://www.ultimatepwc.com/shop/hond...sport-fic.html compare to things currently out there like macsboost, h2oxtreme or parts from magnum tuning such as http://www.magnumtuning.com/en/detai...f-12-arx1200n3 ?
    There is a bit out there but there is also a bit misleading or grey area info regarding tuning or power upgrade limits such as boost on factory turbo on any of the listed items, rev limiter adjustments and the list goes on.
  3. #203
    Top Dog west_coaster's Avatar
    Apr 2005
    San Diego CA
    Now that wiring harnesses are more available/cheaper, it wouldn't be too difficult to adapt a decent mid level, IP 68 type ECM into the Honda. Tuning and support would kill you though. You'd never be able to charge enough to make it worth your time.
    05 F-12X
  4. #204
    Apr 2017
    Spain
    Hi, This is Luis,
    I'm new in the pwc world. I'm trying to upgrade a friend's honda aquatrax f12x mk1 with a microsquirt. I know someone has allready try and ended giving up. I'll give it a new try as long as there is no summer... If there is someone interested in the thread and wouldn't mind to help on the development of the maps it would be appreciated.
    I have allready bought a new harness to star with catting wires and conecting to the apsealed microsquirt... i'll keep updating and asking.
    Luis
  5. #205
    Apr 2018
    PA
    Luis, Did you make any progress with this? I'm considering the same thing.. Did you do any research to see if the MS can fire the factory coils? What about the CAM/CRANK sensors. I'd have no problem modifying the bracket on the cam gear to make it a 1x pickup if needed... I picked up a 2006 F12x Turbo last fall and rebuilt the engine over the winter. I tried to fire it up over the weekend and it seems as if the ECM may be bad. I'm no stranger to aftermarket ECMs and what it takes to tune Turbo engines but I just want to verify the MS will work OK with factory hardware/sensors before I dive into this. Does MS support knock sensor input?
  6. #206
    Apr 2017
    Spain
    Hi Matt,
    Well I'm still waiting for the exhaust manifold to be finished... hopefully today! Aboit the know sensor, yes there is support for it. The ignition coils... I havent tryied yet but i'm sure it will. Those are the sane installed in many honda cars and there they work. The vr sensor on cranck and cam is the main issue. I contacted a guy in Canada that has done it in a cbxx1100 quite same engine. He cutted off tho of the three teeth on cranck rotor. I have made a rotor with 36/1 teeth on cam. Not sure if needed... i'm sure from what i have read that there is no need. Just grinding off those to teeth on cam rotor and the stock rotor on cranck.
    I'll keep posting as soon as there is any thing to mention about the project.
  7. #207
    Apr 2017
    Spain
    Hi! I have been quite busy lately and didn't have much time to continue with the microsquirt project. Today i had the first ignition events. I have not found yet the correct tooth 1 angle yet but very close for sure. I'm working with cop and semi-sequential injector set up. Found, as I said, there is support for knock sensor. Its needed a gm knock sensor unit. i haven't found it yet in the yunkyard..
    At this early stage the set up is quite simple with not many features enable... i will update the features as fas as i get a working tune.
    I have been able to calibrate the oem tps, ego, map and temperature sensors.
    The cam and cranck set up is as follows: oem 12 teeth crank wheel and a one single tooth on cam trigger.
    i'll try to update tomorrow about the trigger configuration.
  8. #208
    Apr 2017
    Spain
    Hi again folks! Finally yestarday night the engine started... still everything needs to be done. But engine running. The problem has allways been the noise affecting the vr cam sensor. New wire with protection agains noise and a 5kohm resistor between both wires. Started right away. Now i'll start with the ignition table and the ve table. I'll try to update.
  9. #209
    Apr 2017
    Spain
  10. #210
    Apr 2018
    PA
    Very cool! Thanks for the updates.
