Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
    Jun 2007
    nashville
    kawasaki sts 750 cranks, but won't start ???
    I'm new to jet skis and my brother in laws recently purchased 1997 kawasaki sts 750 won't start.
    It ran fine for around 8 hrs since he's had it with no problems. Yesterday in the water it ran fine. We turned it off and maybe 5 minutes later when we wanted to ride again we tried to start it but it wouldn't start. It just cranks and cranks. We've tried to choke it but doesn't work. We've tried holding down the throttle but that doesn't work. It is getting spark. The fuel filter is about 1/2 full of fuel. The spark plugs have been replced with new since the problem.
    Any ideas would be helpful. Thanks.
    May 2007
    florida
    Re: kawasaki sts 750 cranks, but won't start ???
    pour a little gas into the carbs to see it fires.
    Take compression in both cylinders.
    check to ensure you have gas in the tank and/or you don't have knob on off or something. go to reserve etc, etc...
    resident guru badassjeep04's Avatar
    North Phoenix
    any fuel leaks? are you getting spark, did you check the ground wire? are you flooded now? you might want to pull the plugs and turn it over some to get some of the fuel out of there, but keep your face away from it or youll be sorry, and check all of the lines comming from the carb, try to blow into one of the fuel lines and look and listen for fuel leaks? did it start when you pulled the cover off, if so then you might have an exaust leak.
    2004 Kawi SXR 800, stock.
    1992 Yami SN 650, Stock
    1985 kawi 440
    05 Dodge ram quad cab
    03 Jeep Wrangler Rubicon, 5 in lift on 35" bfg mudder K/A
    BBSD III = AAAAaaaarrrrrghhh! <--- You guys have to see this! hahahahhaa
    myspace.com/badassjeep04 <--- Add me on My Space
    Jun 2007
    nashville
    Haven't seen any leaks. The tank is and was about 1/2 full, but we did try to set it to the reserve and that was a no go. We pulled the cover and tried to start it, but that didn't work.
    Thanks for the ideas we'll try them.
    North Phoenix
    re post with what you find about the spark and the ground.
    1985 kawi 440
    Jun 2007
    nashville
    It has good spark, but where is the ground wire you speak of?
    PWCToday Guru alexk243's Avatar
    Jun 2007
    Crystal Lake, IL
    fill the tank all the way up (helps it start aka more pressure in the fuel system if you have a leak). also check for an exhaust leak, if will run fine as long as your moving, but as soon as you stop it will fill up the engine compartment with exhaust, try venting the hood and starting it. also pull and clean the plugs, always worked for me
    2007 Kawasaki 800 SXR
    1984 Kawasaki JS550
    North Phoenix
    fallow it from the negative of the batt. to the block, that usuall gets corroded and nasty, but you hvae good spark so i dont know
    1985 kawi 440
    Jun 2007
    nashville
    We grounded the plug to the block and it fired okay that is how we checked the spark.
    Tried the gas in the carbs and it starts fine now. Should I bring tools to the lake to remove the air cleaner or is this something that doesn't happen often?
    Thanks for all the help.
    May 2007
    florida
    It needs fixing. You have a fuel delivery problem.
    the fuel system should be air tight. there is a check valve that allows air in, but not out. check it. On these old skis I always crack the gas cap prior to starting just a little. You should hear air come out. this is a quick check on the fuel system tightness. (Don't completely vent it, just crack until you hear the tank venting and close it).
    If you don't hear the system venting, you need go through the fuel system, vent valve, hoses, connections etc to ensure the system is tight. during operation, the positive pressure from the fuel evaporating ensures you have adaquate net head to the carb. Otherwise, at about a half a tank, it starts miss firing.
    check the tank, filters, ect to ensure they are clean.
