    PWCToday Guru RIVA CREW's Avatar
    Apr 2002
    Pompano Beach, FL, USA
    Now available for Ultra 250X/LX & STX15F/12-F: RIVA Valve Cover Block-off Kit
    PRODUCT:
    APPLICATION(S):
    Kawasaki Ultra 250X, Ultra LX, STX-15F, STX-12F
    PART#:
    RK19090-VCB
    PRODUCT DESCRIPTION:
    Our Valve Cover Block-off Kit is designed to seal off the ports on the valve cover when removing the emission control system for racing applications. There are two major benefits to removing the factory emissions system:
    1) For racing applications it is recommended to remove all necessary equipment from your craft for increased reliability and reduced maintenance. This also cleans up plumbing in the engine compartment providing a clean look.
    2) To accurately monitor air/fuel ration for tuning purposes you must remove the emissions system. The OEM system pumps fresh air into the exhaust stream throwing off air/fuel ratio.
    Plates are precision machined from billet aluminum and anodized to prevent corrosion. Includes two block-off plates and installation instructions.
    IMAGE:
    SUGGESTED RETAIL:
    $ 39.95
    TO ORDER:
    * PARTS ORDERS: 800/241-4544
    * INTERNATIONAL ORDERS: 954/785-2684
    * FAX: 954/785-2535
    * E-MAIL: orders@rivamotorsports.com
    * ONLINE: Click here
    RIVA CREW
    Please ride responsibly!
    PWCToday Guru aznxtacy's Avatar
    Jun 2005
    San Jose, CA
    Re: Now available for Ultra 250X/LX & STX15F/12-F: RIVA Valve Cover Block-off Kit
    Sorry, but I still don't understand what exactly does this cover do? What if I'm bone stock now, will it do anything?
    2004 Kawasaki STX-12F
    AWA Member
    PWCToday Regular Kenneth Canes's Avatar
    Mar 2007
    atlanta
    Quote Originally Posted by aznxtacy
    I'am with you....whats the advantages of this......
    Apr 2002
    They help the engine maintain a consistent and more accurate A/F ratio. This is important for competition and precise tuning. Plus they clean up the look of the engine. Installing them won't hurt the engine or it's performance.
    RIVA CREW
