Results 11 to 19 of 19
Thread: Yamaha xlt 1200
    resident guru sirzappa's Avatar
    Northern Virginia, D.C. area
    Re: Yamaha xlt 1200
    Seems everyone has their own method of doing this. If it is a method, it will probably work. Sometimes mine starts on the first try when cold, but most of the time it doesn't.
    I will definately try some of these.
    '95 Blaster 1 with stuff
    '01 Yamaha XLT1200
    '96 Super Jet...FINALLY
    Mar 2007
    QaTAr
    Re: Yamaha xlt 1200
    i have xlt 1200 '02. I have the same problem after store it for a while i open all the spark plug and put small amount of fuel on each. Put the spark plug back. make sure your fuel line it turn on. It start right up.
    I hope it help. Good luck and have fun.
    Louisiana
    Re: Yamaha xlt 1200
    A big thanks to all of you for your insight!!
    I'm half way there; one started up and the other one's battery is on charge but I'm sure I can get it up and running soon with all of the direction and guidance all of you have suggested.
    Seems like the start up process may be easier with the new four strokes models that are on the market....... I guess once i figure out the routine for getting them going after sitting for a while it will be smooth sailing. At least I hope so.
    Thanks again
    Terry
    Jan 2004
    Atlanta, GA
    Re: Yamaha xlt 1200
    Yup, the 4-stroke (ESPECIALLY the Sea-Doo's since they pressurize the fuel rail as soon as you attach the lanyard) will start basically instantly every single time.
    With that being said, I've always thought that my GP1200R was VERY easy to start compared to most. Seems to me that the Mikuni carbs want to start easier than the Keihin carbs like the Ultra and the STX-1100 use. My SX-R 800 also uses Mikuni carbs and starts very easily as well.
    Current:
    2003 Kawasaki SX-R 800 with FP wet pipe
    2006 Sea-Doo RXP (stock)
    2006 Sea-Doo RXP (minor mods)
    Past:
    2000 Yamaha GP1200R
    2004 Honda R-12X with Macboost stage 2
    nonofyourbusiness
    Re: Yamaha xlt 1200
    I was just looking at primers on ebay, and noticed a buy-one-get-one-free. Since you have two skis... (link)
    I think I'll get a pair and use the second to make a gas siphoning rig. With gas prices as high as they are, I prefer to siphone someone else's.
    PWCToday.com Is My Home Away From Home skysurfer2010's Avatar
    Feb 2004
    Jersey
    Re: Yamaha xlt 1200
    Quote Originally Posted by tginn
    Thanks again
    Terry
    You should really check out that link I posted. The XLT needs mods to make it reliable. If you don't do the mods you could end up with a very expensive paperweight.
    98 SJ
    NJ/PA Crew
    - an AWA Charter Club
    www.njpacrew.org
    I dream skis clar's Avatar
    San Diego
    Re: Yamaha xlt 1200
    The mods D-Plate and wave eater clips are a must , the 4stroke is a easy start push one button wam
    Feb 2004
    Jersey
    Re: Yamaha xlt 1200
    sealing the pump and the pump plug kit is also a must. not only does it prevent cavitation, but the cavitation will cause prop burns over time eventually ruining the prop.
    98 SJ
    NJ/PA Crew
    www.njpacrew.org
    PWCToday Newbie Mr 2 stroke's Avatar
    Jun 2017
    Virginia
    Re: Yamaha xlt 1200
    I just had to bring this back up...... I have had and still have gpr/xlt1200's and never had a starting issue. My method put in key (don't even need choke) then pop starts right up. Where these cats using ethanol-free gasoline or not. Never needed a primer kit or so forth. Just want to know if other have had these issues I know kawi's got it bad but never had an issues myself and I have 12 dif Yamee 1200 over 10 years.
