Results 1 to 6 of 6
    PWCToday Guru grezzmky's Avatar
    Jan 2006
    O'Fallon, Missouri
    AC aluminum hand pole
    is the aluminum pole worth the $300. I know my 650sx is not the perfect freestyle ski but its a good ski for beginers and i want to build it right because i plan on keeping it for others to ride when i get better and upgrade. thanks guys
    P.S. still looking for a total loss, gas door and maybe a 750 motor
    650sx
    custom paint
    trued hull
    shaved gas door
    footholds
    custom turf
    turfed rails
    scuper
    custom 750 "super small pin"
    small pin cases
    stroker crank with 650 rods
    custom Wisecos
    port timing raised w/ 3mm base gasket and
    decked cylinder.
    dual 44 SBN's
    PWCToday.com Is My Home Away From Home Waste Land's Avatar
    Jul 2004
    Florence, AL
    Re: AC aluminum hand pole
    Are you breaking handle poles? If not no
    Jan 2006
    San Antonio, TX
    $300 is too much for an AC pole for a 650sx. I paid $200 for mine shipped to my house from across the country.
    The stock pole weighs a ton and having a lighter aluminum one really cuts down on ski's tendency to tip over because you just have less weigh up in the air. Also my aluminum pole floats at the riding position height with a stock spring and aftermarket spring. It's effortless to hold it up.
    It doesn't matter if you're breaking them or not, the SX pole just kind of sucks. Just post a want ad and you'll probably find one.
    Top Dog rickster's Avatar
    May 2005
    SoFlo Swamp
    I have a modified AC pole, with custom bracket if you really want one.
    PM me for pics...
    90 Limited Freestyle Square / 2006 Superjet, Superstock bigbore/ 96 WaveVenture 1100 being converted to a 701
    SUR#85 AWA Member since 2005
    AllYear
    Guest
    Only if it's new.
    You can get one here:
    http://acracing.com/itemdetails.cfm?...gId=177&id=449
    new for 425 + s/h and choose the lenght and color
    PWCToday.com Is My Home Away From Home SUPERJET-113's Avatar
    Nov 2001
    Havabrew, Havascrew, Havasu!!
    I had 3 650Sx's back in the day and the handle poles are crap as you more than likely know now... I tried repairing them and they still cracked again.. Best best is a AC or MMF alum pole before it breaks and you get hurt.
    KAwasaki poles are all junk. They never had a good OEM stock pole on any models of their ski's...JS to SX-R.
    I would try and find a used one for $150 or so..
    I MAKE EVERY GASKET FOR EVERY 2 STROKE YAMAHA, KAWASAKI, AND SEADOO I CAN HELP! SHOP AND COMPARE!
    CHECK IT OUT: http://www.x-h2o.com/showthread.php?t=57730
