Results 1 to 10 of 12
    Hard starting zxi 1100
    I have a 1998 zxi 1100. It has always been hard to start but once I get it started it runs all day with no problems. I solved the problem by installing a kit that lets me manually pump gas into the carbs before starting it. It seems like I have to pump a lot of gas into the carbs when the engine is cold before it starts. I've heard of others with the same problem who solved it with this kit. Is this common to zxi 1100's, or is there something else I should have done; e.g. rebuilt the carbs?
    PWCToday Guru Snowrider turned Jetskier's Avatar
    Jul 2006
    Dekalb IL
    Re: Hard starting zxi 1100
    Check compression, If low a top end is needed
    PWCToday.com Is My Home Away From Home kawi66's Avatar
    Jan 2003
    kawiland
    common on all the older triple kehin carb models.900 and 1100.
    you did the right thing,a primer. i do about ten a season on customers ski's.they start right up with two pumps on the primer.
    1997 team Kawasaki carbon zxi 1100
    1997 atm lightweight zxi 1100
    Jul 2002
    SC
    Two pumps if the primer is primed. mine sometimes goes dry and then several pumps are required. if you pull the seat you can hear it when it squirts, as well as see the gas and bubbles in the line.
    \'96 1100ZXi
    Yes, the primer fixes the problem but I still can't figure out why all the gas drains from the carbs when the engine cools down and why I need a primer to start it. It shouldn't be that way! My Seadoo doesn't doo that.
    Maybe the pop off pressure is off.
    PWCToday.com Is My Home Away From Home JC545f's Avatar
    Jan 2002
    CA
    Quote Originally Posted by nightshadow
    your primer pump might be leaking air back into the fuel line. Did you install the primer line into the fuel "IN" line going to the carb, or the "OUT" line returning to the fuel.
    Jan 2003
    kawiland
    your sea-doo has mikuni carbs. ALL the kehin carbs are like that,even the later model stxr/ultra ones.
    Jul 2004
    Ks
    I'v had both types of carbs on my ski, CDCV and CDKII, and they both needed a primer. I bought a set of 42mm Keihins and assume I'll have to prime them also.
    The in line. I guess I'll just have to live with using a primer judging by what everyone else is saying. I was hoping to be able to start the ski without using a primer but I guess that's not possible.
    May 2009
    Miami
    Quote Originally Posted by Josh Chipps View Post
    What's the proper line to T for the primmer kit the fuel IN" line or OUT" return line ?
