Largest PWC
Superstore
Collapse
2006 vx110 oil filter
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • yamarider2006
    • Jun 2010
    • 17
    Ok I got found and bought amsiol and ordered amsoil filter online and now starting to change oil and can't find the oil filter!!!! I know laugh but I have shoved my head and hands all over that hull and can't find it! help!!!!
  • misterjay
    • Jun 2009
    • 184
    #2
    Re: 2006 vx110 oil filter
    Its located on the left hand side of the ski as you are sitting on it, its just below the voltage Regulator which is a ridged square metal box, its hard to see but its below the regulator. Its VERY hard to remove !!!! You would be better off to run the ski on the hose for about 5 mins to warm it up, much easier to remove. Its better if you remove a section of the exhaust, its much easier to get at. I used a ratchet and strap, remember to loosen it to the left ! Remove the oil with a suction pump/device. Place an old rag under the filter to catch any spills, remove the filter. Remember to oil the seal of the new filter, tighten and you are done ......
    • yamarider2006
      • Jun 2010
      • 17
      #3
      Thanks for you help! I will try tonight!! thanks again!
      • yamarider2006
        • Jun 2010
        • 17
        #4
        Found it!!! now just need to get that strap for the removal!
        thanks again!
        • almost_there6
          • Aug 2009
          • 102
          #5
          if you get the oil filter socket from Yamaha its very easy to remove
          '92 SN
          '98 GP760
          '94 WB1
          • volltrex
            Top Dog
            • Sep 2006
            • 1682
            #6
            +1.........Also always torque the filter up.......so many get over tightened & then are difficult to remove. Torque is 17 Nm.......can't remember what that is in old money
            sigpic
            Dave
            2007 FXHO 160 Cruiser, Sold
            2012 FXHO Cruiser
            • Chris4x4gill2
              • Jul 2008
              • 9
              #7
              17Nm is about 12.5 ft/lbs I do mine like I do my car, hand tight + 1/4 turn.
              FWIW I use a strap wrench.
              Working...
              X
