If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
so far, I've sent out 6 texts and no issues with either date, but two preferred Wednesday the 30th due to work stuff making it a tight squeeze for tuesday, unless someone chimes in with major blowback, i'm going to plan on sending out a group message on espn setting the date at the 30th, 8pm... as usual the draft should only take 1.5 hours give or take....
The problem with normal is that it just keeps getting worse...
I would rather sit than quit...
______________________________
Advertise here, Low Monthly Rates !
