At what point would you consider a rebuild??
    PWCToday Newbie GarryG's Avatar
    Mar 2018
    Mellons Bay, New Zealand
    I have a '99 Waverunner XL760. At the moment it runs great and not showing any issues, however 2 years ago the compression was showing 140/150 psi. This was done by a service centre. I borrowed a compression tester from a colleague at work and checked it yesterday (don't know if this has been calibrated), anyway, it is showing 120/130 psi.
    So the question arises....When should I consider a top-end rebuild?
    All feedback appreciated.
    Cheers Garry
    PWCToday.com Is My Home Away From Home JSNate's Avatar
    Re: At what point would you consider a rebuild??
    As compression continues to deteriorate, it will take longer to start and performance will suffer. What is most concerning is the disparity between the two cylinders. 10 PSI difference is significant and indicates that one cylinder may have scoring or a damaged ring. A top end is easy to do. Particularity if it does not need a bore. You may be able to get good, even compression with a new set of rings and gaskets.
    Top Dog wire4money's Avatar
    Aug 2008
    Central Oregon
    I believe Yamaha staggers compression, so a 10 psi difference is normal. IIRC, the rear is lower. I would not put too much thought into different numbers using different gauges. If it runs good, run it.
    Oct 2013
    Ohio
    Did you do your compression test with the throttle wide open? if you do it will the throttle closed your numbers may be lower.
    Get one of those little inspection cameras, like used for looking into walls, take a look in the cylinders for damage.
    2, 1998 TS 770 L, restored and running great as of July 2019 (NO THANKS to the person at SBT, who put the WRONG crankshaft bearing into the rebuilt engine I got from them)
    Mar 2018
    Quote Originally Posted by hemmjo View Post
    Was just a push on gauge, so didn't have enough hands I just pushed on the top and turned the starter, so no throttle.
    Mar 2018
    I have been told that the cmpression is staggered, so not to bothered about the difference.... Might try it again after reading Hemmjo's comments... Cheers
    If it runs fine, just ride it. I am sure you'll be good for a long time.
    Please visit our web site
    PWCToday.com Is My Home Away From Home Benflynn's Avatar
    Birmingham
    U can take the head off pretty easy and see what's going on down there, anyways you want to rebuild right before or right after it breaks
    Quote Originally Posted by GarryG View Post
    I've done some research regarding some 760 engines Yamaha installed in sit down PWC in that era. And I was surprised to find information on "staggered compression" on some of the 760's built. I could not find information on how it was attained with the engineering/design of the 760. I assume that it most likely comes from the cylinder head squish cut.? But, information did state that a 5 PSI difference is considered "normal" on these engines.
    Any 760 or 701 I've worked on/modified always had even compression. So, I've never witnessed it first hand. I am glad that I came across your thread and learned something I was not aware of. I am currenlty running a ported 760 in one of my AM hulls and with a Pro-Tec head, compression is even at 183 PSI. I have another 760 lined up for my next build and that engine is stock with compression at 150/150 PSI.
    Also, I too have found a difference between brands and quality of gauges that will read lower PSI than a better gauge. If she starts easily and runs strongly, you are probably fine and good to go.
    Good luck and have fun!
