  • 08-02-2022, 01:24 PM
    jackball42
    Aquatrax turbo wont go above about 10mph
    I have a Turbo Aquatrax that wont go above about 10mph/3500 rpm max. I replaced the turbo solenoid (based on a test procedure I found )and replaced the pump bearing that was worn out. I'm starting to lean toward the turbo. I bought this ski used and someone has been in the turbo previously (rtv on housing). The impeller vanes show signs of wear. How do you test the turbo or determine if that is the cause of my issues?
    I've read some posts about error codes. Where do you find these? Is there a blink code on the instrument cluster? Sorry, I'm new to this ski.
  • 08-04-2022, 11:43 PM
    RenoJetTech
    Re: Aquatrax turbo wont go above about 10mph
    I wonder you have a exhaust leak choking the motor or bad plugs, though those other issues not good.
    Compression test ?
  • 08-04-2022, 11:48 PM
    RenoJetTech
    check air filter if you never have
