  • 01-08-2019, 05:34 PM
    jobrown
    20 Attachment(s)
    86 X2 The Arkansas Backyard Find
    This 86 X2 has seen better days, but not in a very long time. The following is what I have done so far and what I plan to do next. Its a lot, but please read and comment as you wish. I love feedback and if anyone catches me making a mistake please let me know!
    I found this beauty in the backyard of a guy here in Arkansas and traded a pistol for it because... well... Arkansas... It has been sitting for quite some time from the looks of the decals, mud in the pump and the 1999 registration stickers. Opening the hood I saw the Mariner head, which peaked my interest. The starter only came alive in fits and wasn't turning over well enough for a compression reading. Turned her over to find the stainless impeller and thought aw heck why not and threw it in the back of the Jeep and went home with a new baby. 32 year old baby.
    Attachment 545933Attachment 545934Attachment 545935
    Got it home and started pulling things apart. My God. Oil in the flywheel cover, blown crank seals, broken motor mounts, torn through hull fittings, carb that looks to be missing half its internals, and a set of scored stock pistons. And apparently aftermarket reeds. Whoever modified this thing had some thoughts. High compression head and dual stage reeds with the 28mm carb and stock exhaust. Maybe that was the kind of thing he was into?
    Attachment 545936Attachment 545937Attachment 545938
    I've been on a parts hunt as I've saved a bit of cash here and there. The upgrades of work done and parts bought go as follows:
    Bought some things to help the ski breathe in and out a little better. SBN44 with L-S flame arrestor and a Coffmans Exhaust with the updated stock manifold with diverter.
    Sent the cylinders/head and flywheel off to Newmiller Machine. New WSM pistons where fit into the freshly bored and honed cylinders and Newmiller lightened the stock flywheel. He also measured the head volume for me and was able to recommend head gasket and timing options to fit different octane fuels. In short, with a stock head gasket I will need to run race fuel... which Id rather not. So I'll be looking for a copper .020 gasket in order to stay in the 93 range.
    Attachment 545943Attachment 545949
    The pump, after removing a fair amount of mud, looks decent enough. Pulling the pump cone was another story entirely. Mud and water had leaked in and soaked the bearings. Though after cleaning the seem to spin free without any noise, I dont know if I can trust them so they will need to be replaced. The Solas impeller is for sale. I had an X2 a few years ago with a skat 9/17 and loved it so thats what I'll be looking for again. I was able to source a decent through hull fitting and used motor mounts on here as well as a stubby pump cone.
    Attachment 545939Attachment 545940Attachment 545941Attachment 545950
    The hull is in pretty rough shape. I did a tap around the top and bottom while cleaning looking for soft spots, found one on the bottom and removed the soft glass and sanded back until I was with the good hard stuff again. Epoxy resin from U.S Composites will be used throughout the ski for repairs. I can tell there are a few major spots besides this hole, including the nose and the hood that will need some surgery. I might need to order some more resin.
    Attachment 545942Attachment 545945Attachment 545948Attachment 545951Attachment 545952
    There appears to be a patch of kitty hair glass and resin on the front of the ski around the waterline. Not sure if I should investigate that or not...
    Attachment 545946
    And thanks to a member on here I got some sweet decals second hand that he couldnt use on his build... I know its an 86 but I love those 93 graphics!
    Attachment 545947
    Next steps:
    I still have a bunch of parts to source, namely a Skat 9/17 and an intake for that SBN44, as well as a starter.
    Paint is going to be its own thing entirely. After glass work I will need to source an epoxy primer, and then figure out how I want to paint it. I've heard boat guys swear by Interlux Perfection with the roll and tip method, friends think I should just take it to shop and have them spray it with automotive paint and be done with it, and I have personally used the thinned out rustoleum roll on method which requires a ton of coats (8 in my case, but that was a black ski) and a lot of sanding and buffing. The ski I did this way turned out amazing, but boy it was a lot of work.
    Attachment 545953
  • 01-08-2019, 07:03 PM
    jafaboy
    Re: 86 X2 The Arkansas Backyard Find
    Nice work fitting it in the jeep, i 'heard' they were tested to carry a 650sx with the front seat down :)
  • 01-09-2019, 01:31 PM
    Myself
    Quote:
    Ya, I remember seeing that in the factory manual, lol!
  • 01-09-2019, 04:39 PM
    Rod Peters
    Certainly a project, have done many just like it, little time and money and it will be worth it.
  • 01-09-2019, 04:52 PM
    jobrown
    3 Attachment(s)
    Quote:
    It was snug... Attachment 545983Attachment 545984Attachment 545987
  • 01-10-2019, 08:43 AM
    afraz1er
    If the pump is beyond saving i have one with the nozzles I'll sell cheap. Oem impeller.
    Sent from my SM-G892U using Tapatalk
  • 01-10-2019, 11:31 PM
    jobrown
    1 Attachment(s)
    I was just going to do new pump bearings though I admit I’ve never done them before...
    This should help add a little braapp* to that old motor! Obviously some polishing is in my future. Stock exhaust added above for size comparison. Attachment 546018
  • 01-22-2019, 11:45 AM
    afraz1er
    If that's the bigger Coffman with the 4.5" chamber you dont want that. You should sell it to me instead.
  • 01-22-2019, 03:48 PM
    jobrown
    1 Attachment(s)
    Oh nooooo ��
    Attachment 546293
